MeloSpace
Import images dynamically using require.context
December 27, 2019
A friend recently asked me a perculiar problem. She was trying to build a carousel that cycles through multiple images in a directory for a React app bootstrapped using Create-react-app.
While hard-coding for a couple of images seem like a trivial solution, the problem was trying to display an arbitrary number of images, each with a filename not known before hand.
Psst: If you want the tldr fix, scroll right down to the bottom. In the next section, I’ll briefly document what I have tried why trying to solve this issue.
Attempt 1
Read filenames from dir
First, I read in filenames using fs.readdirSync(), a method that returns an array of filenames in the given directory.
const imgFolder = './assets/';
const fs = require('fs');
fs.readdirSync(imgFolder).forEach(file => {
  console.log(file); // 'brave.png'
Use a for loop and require image individually
  const img_src = require(`${imgFolder}${file}`);
  return <img src={img_src}/>;
This, however, raised an error of the form: the path ‘./assets/brave.png’ cannot be found in the browser (the compilation was successfully using npm start).
After researching more, I realised that require only work with static paths (i.e. a hardcoded path instead of a path stored in a variable). This is because Create-react-app uses Webpack under the hood [1] and as a bundler, you have to specify a context where the images are loaded.
One of the main features of webpack’s compiler is to recursively parse all the modules and to build a graph of module dependencies. The definition of context in Webpack is used as a base to resolve paths to modules. For instance, the default context is __dirname. [2]
Attempt 2: Solution
Using require.context to create a customised context
You can create your own context with the require.context function. It allows you to pass three parameters: [3]
  • the directory to match within,
  • a boolean flag to include or exclude subdirectories,
  • a regular expression to match files against.
require.context(directory, useSubdirectories = false, regExp = /^**\.\/**/)
// To solve the problem
const imgFolder = require.context('./assets/', useSubdirectories = false)
const img_node = images(`./${someVariable}.png`);
return <img src={img_node}/>;
To read more about require.context and how it can import multiple contexts at once refer to [3].
References
[1] https://github.com/facebook/create-react-app
[2] https://stackoverflow.com/questions/54059179/what-is-require-context
[3] https://webpack.js.org/guides/dependency-management/
Written by Melodies Sim who lives and works in the Bay Area, California turning novel ideas into reality. Check out her projects on Github.
